주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G Pad F 7.0 Motherboard Replacement
필요한 것
  1. LG G Pad F 7.0 Motherboard Replacement, Rear Camera: 1 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Motherboard Replacement, Rear Camera: 1 단계, 이미지 2개 중 2개
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out
    • Remove SIM card and set aside
  2. LG G Pad F 7.0 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the plastic opening tool to pry up the ribbon cable connecting to the camera unit.
    • One the ribbon cable has been detached, use the tweezers to pull up the camera. It is attached with adhesive so pull up gently to remove it.
    • Once the old camera unit is removed, replace with new unit and reassemble in reverse order of guide.
  4. LG G Pad F 7.0 Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  5. LG G Pad F 7.0 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
  6. LG G Pad F 7.0 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the front facing camera ribbon cable attachment on the motherboard
    • Leave the ribbon cable disconnected.
  7. LG G Pad F 7.0 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the six Phillips head screws on the LG G Pad F 7.0 Motherboard
    • Use Phillips #0 Screwdriver to unscrew the six screws.
  8. LG G Pad F 7.0 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the motherboard by prying it out with the plastic opening tool (as shown in image).
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jose Hurtado
회원 가입일: 01/25/17
329 평판
안내서 2개를 작성함
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G5
3 회원들
안내서 10개를 작성함
1가이드 댓글
Some spelling errors but overall simple to follow
Jonah Basl - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 9
전체 시간: 721
