주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G Pad F 7.0 Rear Camera Replacement
필요한 것
    1. LG G Pad F 7.0 Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2개 중 2개
      • Open up the SIM port, on the top right corner (screen face down).
      • Press the SIM card (white plastic) to pop it out
      • Remove SIM card and set aside
      댓글 쓰기
    2. LG G Pad F 7.0 Rear Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
      • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
      • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
      댓글 쓰기
    3. LG G Pad F 7.0 Rear Camera Replacement: 3 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Rear Camera Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the plastic opening tool to pry up the ribbon cable connecting to the camera unit.
      • One the ribbon cable has been detached, use the tweezers to pull up the camera. It is attached with adhesive so pull up gently to remove it.
      • Once the old camera unit is removed, replace with new unit and reassemble in reverse order of guide.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Matt Kloos
회원 가입일: 01/25/17
249 평판
안내서 2개를 작성함
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G5
3 회원들
안내서 30개를 작성함
2가이드 댓글
There are multiple spelling errors throughout the guide
Jonah Basl - 답글 공유
Where? I reread and didn't find any.
Matt Kloos - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 529
