주요 콘텐츠로 건너뛰기
LG G Pad F 7.0 Speaker Replacement
필요한 것
  1. LG G Pad F 7.0 Speaker Replacement, Speaker: 1 단계, 이미지 1/2 LG G Pad F 7.0 Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Speaker Replacement: 2 단계, 이미지 1/2 LG G Pad F 7.0 Speaker Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Speaker Replacement: 3 단계, 이미지 1/3 LG G Pad F 7.0 Speaker Replacement: 3 단계, 이미지 2/3 LG G Pad F 7.0 Speaker Replacement: 3 단계, 이미지 3/3
    • Locate the LG G Pad F 7.0 speaker
    • Insert the plastic opening tool on an edge of the speaker and lift so that it comes off easily
    • Remove old speaker and replace with a new one
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jose Hurtado
회원 가입일: 01/25/17
329 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 183
