주요 콘텐츠로 건너뛰기
LG G Pad F 8.0 Battery Replacement
필요한 것
  1. LG G Pad F 8.0 Battery Replacement, Back Cover: 1 단계, 이미지 1/2 LG G Pad F 8.0 Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Battery Replacement: 2 단계, 이미지 1/2 LG G Pad F 8.0 Battery Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to pry the back cover off of the tablet.
    • Work your way all the way around the edge of the screen, and remove the back cover when it is loose.
  3. LG G Pad F 8.0 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Disconnect the large, yellow ribbon using the iFixit opening tool.
  4. LG G Pad F 8.0 Battery Replacement: 4 단계, 이미지 1/1
    • Pry up on the multi-color ribbon with the iFixit opening tool to disconnect it.
  5. LG G Pad F 8.0 Battery Replacement: 5 단계, 이미지 1/2 LG G Pad F 8.0 Battery Replacement: 5 단계, 이미지 2/2
    • Use the iFixit opening tool to pry up the four edges of the battery.
    • Remove the battery from the tablet.
결론
Noah Trevino
회원 가입일: 02/09/23
353 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 278
