주요 콘텐츠로 건너뛰기
LG G Pad F 8.0 Motherboard Replacement
필요한 것
  1. LG G Pad F 8.0 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 LG G Pad F 8.0 Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Motherboard Replacement: 2 단계, 이미지 1/2 LG G Pad F 8.0 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to pry the back cover off of the tablet.
    • Work your way all the way around the edge of the screen, and remove the back cover when it is loose.
  3. LG G Pad F 8.0 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Disconnect the large, yellow ribbon using the iFixit opening tool.
  4. LG G Pad F 8.0 Motherboard Replacement: 4 단계, 이미지 1/3 LG G Pad F 8.0 Motherboard Replacement: 4 단계, 이미지 2/3 LG G Pad F 8.0 Motherboard Replacement: 4 단계, 이미지 3/3
    • Use the iFixit opening tool to disconnect the multicolor wire cables from the motherboard.
    • Disconnect the top of the orange ribbon cable from the motherboard.
    • Detach the front facing camera ribbon cable from the motherboard.
  5. LG G Pad F 8.0 Motherboard Replacement: 5 단계, 이미지 1/3 LG G Pad F 8.0 Motherboard Replacement: 5 단계, 이미지 2/3 LG G Pad F 8.0 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the seven 2 mm screws using a Phillips #0 screwdriver.
    • Use the iFixit opening tool and pry up on the motherboard to remove it.
결론
Angel Padilla
회원 가입일: 02/09/23
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 103
