주요 콘텐츠로 건너뛰기
LG G Pad F 8.0 Rear Camera Replacement
필요한 것
  1. LG G Pad F 8.0 Rear Camera Replacement, Back Cover: 1 단계, 이미지 1/2 LG G Pad F 8.0 Rear Camera Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Rear Camera Replacement: 2 단계, 이미지 1/2 LG G Pad F 8.0 Rear Camera Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to pry the back cover off of the tablet.
    • Work your way all the way around the edge of the screen, and remove the back cover when it is loose.
  3. LG G Pad F 8.0 Rear Camera Replacement, Rear Camera: 3 단계, 이미지 1/3 LG G Pad F 8.0 Rear Camera Replacement, Rear Camera: 3 단계, 이미지 2/3 LG G Pad F 8.0 Rear Camera Replacement, Rear Camera: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the plastic opening tool to pry up the ribbon cable of the rear camera.
    • When the ribbon is loose, use the tweezers to pull up on the camera to remove.
    • Replace the old camera with the new one.
결론
Noah Trevino
회원 가입일: 02/09/23
353 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 72
