소개
This guide will take you through the very easy process of replacing the downward facing speaker that has either died or blown out.
필요한 것
Power off the device before starting speaker replacement.
Remove SD card and SIM Card.
With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
