주요 콘텐츠로 건너뛰기
LG G Pad X 8.3 Battery Replacement
필요한 것
  1. LG G Pad X 8.3 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the cover of the SD card. Find it on the right side of the back of the tablet.
    • Press the SD card in to make it pop out.
  2. LG G Pad X 8.3 Battery Replacement: 2 단계, 이미지 1/1
    • Slide the stylus out from the bottom left corner of the back panel.
  3. LG G Pad X 8.3 Battery Replacement: 3 단계, 이미지 1/1
    • Start at a corner and pry the screen up with a plastic opening tool.
    • You can also use a plastic spudger for this task, but do not use metal tools. They can be dangerous to you and the device.
    • Slide the tool in the seam at the edge of the screen.
    • Wedge additional plastic opening tools in the seam to help lift the screen.
    • Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
    • If your screen is cracked, work slowly to avoid flinging glass shards when prying.
  4. LG G Pad X 8.3 Battery Replacement: 4 단계, 이미지 1/3 LG G Pad X 8.3 Battery Replacement: 4 단계, 이미지 2/3 LG G Pad X 8.3 Battery Replacement: 4 단계, 이미지 3/3
    • With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
    • With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
    • Use a magnetic mat to keep track of these tiny screws for later reassembly.
  5. LG G Pad X 8.3 Battery Replacement: 5 단계, 이미지 1/1
    • Lift the battery ribbon connector with your finger.
  6. LG G Pad X 8.3 Battery Replacement: 6 단계, 이미지 1/1
    • Lift the battery with your fingers and remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Roxanne McPeck
회원 가입일: 04/09/18
345 평판
안내서 1개 작성함
댓글 2개
This looks to be a helpful Guide, but there is no help in WHERE to purchase a battery and if there could be a different battery with higher capacity and a longer life as a choice. As a Consumer, this type of information would be helpful.
Harvey Rothenberg - 답글
I cannot get a wedge tool in to remove the screen on my LG G Pad X 10.1. Any suggestions?
Hillary Brandeberry - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 5,308
