소개
The motherboard is the foundation of any electronic device. This guide will walk you through the replacement of one of the most essential components of the LG G Pad X 8.3.
필요한 것
Remove the cover of the SD card. Find it on the right side of the back of the tablet.
Press the SD card in to make it pop out.
With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
Use the magnetic mat to keep track of the tiny screw(s).
With the Phillips #000 screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
Use a plastic opening tool to lift up the ribbon connector at the bottom of the motherboard.
The end of this flex is a small connector that is hidden under a piece of adhesive. Carefully pull this up or the end will tear off.
Lift and release the remaining ribbon connectors in the upper left corner of the motherboard with a plastic opening tool.
