주요 콘텐츠로 건너뛰기
LG G Stylo Battery Replacement
필요한 것
  1. LG G Stylo Battery Replacement, Battery: 1 단계, 이미지 1/2 LG G Stylo Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Battery Replacement: 2 단계, 이미지 1/2 LG G Stylo Battery Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
    My phone is showing USB when charging instead of AC and when removing the charger it's show discharging instead of Not charging.... Don't know why it is not working properly....
    George japhet - 답글
    I need help urgently please
    George japhet - 답글
결론
다른 6명이 해당 안내서를 완성하였습니다.
Douglas Schmidt
회원 가입일: 02/09/16
422 평판
안내서 2개 작성하였습니다
USF Tampa, Team 11-7, Cheng Spring 2016 USF Tampa, Team 11-7, Cheng Spring 2016 회원
USFT-CHENG-S16S11G7
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Thank you for your help. This has been making us crazy, your time is much appreciated.
Desi Young - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 64
전체 시간: 12,886
