주요 콘텐츠로 건너뛰기
LG G Stylo Speaker Replacement
필요한 것
  1. LG G Stylo Speaker Replacement, Battery: 1 단계, 이미지 1/2 LG G Stylo Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Speaker Replacement: 2 단계, 이미지 1/2 LG G Stylo Speaker Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
  3. LG G Stylo Speaker Replacement, Speaker: 3 단계, 이미지 1/2 LG G Stylo Speaker Replacement, Speaker: 3 단계, 이미지 2/2
    • Carefully use the 3.9mm Phillips #00 screwdriver to remove the eleven visible screws found on the back. The screws to be removed are marked with the given indicators.
  4. LG G Stylo Speaker Replacement: 4 단계, 이미지 1/2 LG G Stylo Speaker Replacement: 4 단계, 이미지 2/2
    • When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
    • This part could be more difficult if you have never removed the motherboard cover. If difficulty arises, pry the plastic opening tool into each groove along the edge of the motherboard cover until it releases.
    • Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
  5. LG G Stylo Speaker Replacement: 5 단계, 이미지 1/3 LG G Stylo Speaker Replacement: 5 단계, 이미지 2/3 LG G Stylo Speaker Replacement: 5 단계, 이미지 3/3
    • Once you have the plastic back cover exposed you can detach the speaker
    • Indicated on the back panel is where you will use your plastic prying tool to remove the top part from the speaker.
    • The bottom part of the plastic panel contains the speaker which should be placed all as one part.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Kimberly Young
회원 가입일: 02/09/16
761 평판
안내서 3개 작성하였습니다
USF Tampa, Team 11-7, Cheng Spring 2016 USF Tampa, Team 11-7, Cheng Spring 2016 회원
USFT-CHENG-S16S11G7
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 5,011
