소개
If you are having problems with the audio performance on your phone and you have determined that the speaker is the issue, this guide will walk you through on how to change the speaker part.
도구
부품
Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
Carefully use the 3.9mm Phillips #00 screwdriver to remove the eleven visible screws found on the back. The screws to be removed are marked with the given indicators.
다른 5명이 해당 안내서를 완성하였습니다.
