주요 콘텐츠로 건너뛰기
LG G Vista Charging Dock Replacement
필요한 것
  1. LG G Vista Charging Dock Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the device is powered off.
  2. LG G Vista Charging Dock Replacement: 2 단계, 이미지 1/1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Charging Dock Replacement: 3 단계, 이미지 1/1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Charging Dock Replacement, Charging Dock: 4 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the eleven 3.0 mm screws around the perimeter of the phone.
  5. LG G Vista Charging Dock Replacement: 5 단계, 이미지 1/1
    • Use a plastic spudger, or finger nail, to lift up the hard shell on the top of the phone.
  6. LG G Vista Charging Dock Replacement: 6 단계, 이미지 1/2 LG G Vista Charging Dock Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the five 3.0 mm screws.
    • Remove the bottom hard shell from the device.
  7. LG G Vista Charging Dock Replacement: 7 단계, 이미지 1/2 LG G Vista Charging Dock Replacement: 7 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the two screws from the device.
  8. LG G Vista Charging Dock Replacement: 8 단계, 이미지 1/1
    • Using a pair of tweezers, lift up the two antennas surrounding the battery.
  9. LG G Vista Charging Dock Replacement: 9 단계, 이미지 1/1
    • Disconnect the two connectors on the right side of the charging port.
  10. LG G Vista Charging Dock Replacement: 10 단계, 이미지 1/1
    • Lift up the charging port with the plastic opening tool.
    • Remove the charging port from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Key Baker
회원 가입일: 01/18/18
754 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 12
전체 시간: 638
