주요 콘텐츠로 건너뛰기
LG G Vista Screen Replacement
필요한 것
  1. LG G Vista Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the device is powered off.
  2. LG G Vista Screen Replacement: 2 단계, 이미지 1/1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Screen Replacement: 3 단계, 이미지 1/1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Screen Replacement, Screen: 4 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove all eleven 3.0 mm screws from around the perimeter of the phone.
  5. LG G Vista Screen Replacement: 5 단계, 이미지 1/1
    • Use a plastic spudger or opening tool and run it along the seam of the upper cover.
    • Carefully remove the cover from the device.
  6. LG G Vista Screen Replacement: 6 단계, 이미지 1/1
    • Use the same method to pry off the hard shell covering at the bottom.
  7. LG G Vista Screen Replacement: 7 단계, 이미지 1/1
    • Remove the two 1 mm Phillips #000 screws.
  8. LG G Vista Screen Replacement: 8 단계, 이미지 1/2 LG G Vista Screen Replacement: 8 단계, 이미지 2/2
    • Gently using tweezers, disconnect the connector that is on the bottom right.
  9. LG G Vista Screen Replacement: 9 단계, 이미지 1/2 LG G Vista Screen Replacement: 9 단계, 이미지 2/2
    • Gently unplug the antenna wires on the bottom left and right sides of the device.
  10. LG G Vista Screen Replacement: 10 단계, 이미지 1/1
    • With your plastic opening tool, gently lift up the bottom edge of the exposed charging port, sliding along the edge until it lifts out.
  11. LG G Vista Screen Replacement: 11 단계, 이미지 1/1
    • Using tweezers, unplug the four connectors.
  12. LG G Vista Screen Replacement: 12 단계, 이미지 1/2 LG G Vista Screen Replacement: 12 단계, 이미지 2/2
    • Remove the antenna wires on both sides of the device.
  13. LG G Vista Screen Replacement: 13 단계, 이미지 1/2 LG G Vista Screen Replacement: 13 단계, 이미지 2/2
    • Carefully lift out the back camera from the device.
    • Lift out the headphone jack in the upper right side of the device.
  14. LG G Vista Screen Replacement: 14 단계, 이미지 1/1
    • Remove the motherboard from the phone.
  15. LG G Vista Screen Replacement: 15 단계, 이미지 1/1
    • Remove the vibration motor from the device.
    • You will be left with the entire display assembly of the device.
결론
To reassemble your device, follow these steps in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Key Baker
회원 가입일: 01/18/18
754 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 729
