소개
This guide will show you how to replace the motherboard in your LG G Watch.
필요한 것
First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
Grasp the exposed shoulder with the tweezers to perform the next step.
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
Use the spudger to gently lift up and disconnect the display connector.
Now use the spudger to disconnect the digitizer connector.
다른 4명이 해당 안내서를 완성하였습니다.
