소개
In addition to protecting the internal components of the watch, the back case also fastens the power charging conductor and heart rate monitor to the watch's motherboard.
필요한 것
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
So i bought a torx t5…but it is tooo big. It must br torx t4
Jetze Kooistra - 답글
I think I have damaged one of the screw heads while trying to unscrew the back of the watch.
I used the Torx T4… but the screw was covered in quite a bit of rust. Now the Torx T4 can’t get a grip.
What should I do? (Can anything be done?)
John Maher - 답글
Yea take a tiny file or a tiny Dremel attachment and carve a flat head groove in the head just enough so where you can use a flat head to get it
Andrew L rambeaut -
Thank you for good instructions! Saved me for 300€ (don’t have to buy a new wacth) ?
Ernst Kranke - 답글
