주요 콘텐츠로 건너뛰기
LG G Watch R Battery Housing
필요한 것
  1. LG G Watch R Battery Housing, Back Case: 1 단계, 이미지 2개 중 1개 LG G Watch R Battery Housing, Back Case: 1 단계, 이미지 2개 중 2개
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Battery Housing: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Housing: 3 단계, 이미지 1개 중 1개
    • Remove the back case.
  4. LG G Watch R Battery Housing, Motherboard: 4 단계, 이미지 2개 중 1개 LG G Watch R Battery Housing, Motherboard: 4 단계, 이미지 2개 중 2개
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Battery Housing: 5 단계, 이미지 2개 중 1개 LG G Watch R Battery Housing: 5 단계, 이미지 2개 중 2개
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Battery Housing: 6 단계, 이미지 1개 중 1개
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Housing, Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
  8. LG G Watch R Battery Housing, Battery Housing Replacement: 8 단계, 이미지 2개 중 1개 LG G Watch R Battery Housing, Battery Housing Replacement: 8 단계, 이미지 2개 중 2개
    • Pry the battery housing from the top right corner using a spudger.
    • Once loosened, remove the battery housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G1
5 회원들
안내서 14개를 작성함
댓글 한 개
Hi there, do you know where can i buy the battery housing? Thank you..
Eugene Kang - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 1,594
