주요 콘텐츠로 건너뛰기
LG G Watch R Battery Replacement Replacement
필요한 것
  1. LG G Watch R Battery Replacement Replacement, Back Case: 1 단계, 이미지 1/2 LG G Watch R Battery Replacement Replacement, Back Case: 1 단계, 이미지 2/2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Battery Replacement Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Replacement Replacement: 3 단계, 이미지 1/1
    • Remove the back case.
  4. LG G Watch R Battery Replacement Replacement, Motherboard: 4 단계, 이미지 1/2 LG G Watch R Battery Replacement Replacement, Motherboard: 4 단계, 이미지 2/2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Battery Replacement Replacement: 5 단계, 이미지 1/2 LG G Watch R Battery Replacement Replacement: 5 단계, 이미지 2/2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Battery Replacement Replacement: 6 단계, 이미지 1/1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Replacement Replacement, Battery Replacement: 7 단계, 이미지 1/1
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
결론
다른 70명이 해당 안내서를 완성하였습니다.
Westley Courchene
회원 가입일: 01/13/15
3,362 평판
안내서 14개 작성하였습니다
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G1
5 회원들
안내서 14개 작성하였습니다
댓글 13개
It did help, small correction - Use a T4 instead of T5 screw driver
Suyog Patki - 답글
On my G Watch R the T5 screw driver perfektly fits.
igor-sweet -
I second the fonejoy link, got it delivered from them very quickly. And I also second what Suyog said regarding the Torx screwdriver, on my own watch I needed a T4, the T5 didn't work, but I had a set so I was okay.
Mike - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 77
전체 시간: 29,861
