주요 콘텐츠로 건너뛰기
LG G Watch R Power Button
필요한 것
  1. LG G Watch R Power Button, Back Case: 1 단계, 이미지 2개 중 1개 LG G Watch R Power Button, Back Case: 1 단계, 이미지 2개 중 2개
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Power Button: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Power Button: 3 단계, 이미지 1개 중 1개
    • Remove the back case.
  4. LG G Watch R Power Button, Motherboard: 4 단계, 이미지 2개 중 1개 LG G Watch R Power Button, Motherboard: 4 단계, 이미지 2개 중 2개
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Power Button: 5 단계, 이미지 2개 중 1개 LG G Watch R Power Button: 5 단계, 이미지 2개 중 2개
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Power Button: 6 단계, 이미지 1개 중 1개
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Power Button, Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
  8. LG G Watch R Power Button, Battery Housing Replacement: 8 단계, 이미지 2개 중 1개 LG G Watch R Power Button, Battery Housing Replacement: 8 단계, 이미지 2개 중 2개
    • Pry the battery housing from the top right corner using a spudger.
    • Once loosened, remove the battery housing.
  9. LG G Watch R Power Button, Power Button: 9 단계, 이미지 3개 중 1개 LG G Watch R Power Button, Power Button: 9 단계, 이미지 3개 중 2개 LG G Watch R Power Button, Power Button: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • On the power button, locate a small grey washer on the interior side of the watch.
    • Use a pair of tweezers or another pointed object to push the washer out of its socket, and remove the power button.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G1
5 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 2,675
