소개
Use this guide to replace the rear case on your LG G Watch.
  1. Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband. Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  5. Slide the opening pick between the rear case and the rest of the device to separate the two halves. Gently pull the two halves apart.
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 2013년 09월 30일
74,396 평판
안내서 84개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 611
