주요 콘텐츠로 건너뛰기
LG G Watch Wristband Replacement
필요한 것
  1. LG G Watch Wristband Replacement, Wristband: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Wristband Replacement: 2 단계, 이미지 2개 중 1개 LG G Watch Wristband Replacement: 2 단계, 이미지 2개 중 2개
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Deja Miller
회원 가입일: 10/14/14
462 평판
안내서 3개를 작성함
USF Tampa, Team 2-5, Blackwell Fall 2014 USF Tampa, Team 2-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S2G5
5 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 8
전체 시간: 883
