필요한 것
Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
Pry upward and the cover should pop off easily.
Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
Now you are able to replace the battery with a new one.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
