주요 콘텐츠로 건너뛰기
LG G2 mini LTE Front Facing Camera Replacement
필요한 것
  1. LG G2 mini LTE Front Facing Camera Replacement, Remove the Battery Cover: 1 단계, 이미지 1/1
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily.
  2. LG G2 mini LTE Front Facing Camera Replacement, Remove the Battery: 2 단계, 이미지 1/1
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  3. LG G2 mini LTE Front Facing Camera Replacement, Unscrew the Motherboard Cover: 3 단계, 이미지 1/2 LG G2 mini LTE Front Facing Camera Replacement, Unscrew the Motherboard Cover: 3 단계, 이미지 2/2
    • Locate 10 screws and remove each one using a Philips head screw driver.
  4. LG G2 mini LTE Front Facing Camera Replacement, Remove the Motherboard Cover: 4 단계, 이미지 1/1
    • Use a plastic spudger tool to pry away the cover by placing it between the cover and the phone.
    • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
  5. LG G2 mini LTE Front Facing Camera Replacement, Remove the Front Facing Camera: 5 단계, 이미지 1/3 LG G2 mini LTE Front Facing Camera Replacement, Remove the Front Facing Camera: 5 단계, 이미지 2/3 LG G2 mini LTE Front Facing Camera Replacement, Remove the Front Facing Camera: 5 단계, 이미지 3/3
    • Locate the front facing camera.
    • Pry the ribbon cable off of it's connector using the plastic spudger tool or a flat head screwdriver.
    • Use your finger to remove the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aung Myin Thu Mayet
회원 가입일: 10/29/14
641 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-9, Shastany Fall 2014 UMass Dartmouth, Team 1-9, Shastany Fall 2014 회원
UMASSD-SHASTANY-F14S1G9
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 1,408
