주요 콘텐츠로 건너뛰기
LG G2 mini LTE Headphone Jack Replacement
필요한 것
  1. LG G2 mini LTE Headphone Jack Replacement, Remove the Battery Cover: 1 단계, 이미지 1/1
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily.
  2. LG G2 mini LTE Headphone Jack Replacement, Remove the Battery: 2 단계, 이미지 1/1
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  3. LG G2 mini LTE Headphone Jack Replacement, Unscrew the Motherboard Cover: 3 단계, 이미지 1/2 LG G2 mini LTE Headphone Jack Replacement, Unscrew the Motherboard Cover: 3 단계, 이미지 2/2
    • Locate 10 screws and remove each one using a screw driver.
  4. LG G2 mini LTE Headphone Jack Replacement, Remove the Motherboard Cover: 4 단계, 이미지 1/1
    • Use a plastic spudger tool to pry away the cover by placing it between the cover and the screen bezel.
    • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
  5. LG G2 mini LTE Headphone Jack Replacement, Remove Headphone jack: 5 단계, 이미지 1/3 LG G2 mini LTE Headphone Jack Replacement, Remove Headphone jack: 5 단계, 이미지 2/3 LG G2 mini LTE Headphone Jack Replacement, Remove Headphone jack: 5 단계, 이미지 3/3
    • Locate the headphone jack.
    • Use spudger tool to pry the headphone jack from the bottom.
    • Use fingers to fully remove the headphone jack.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Aung Myin Thu Mayet
회원 가입일: 10/29/14
641 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-9, Shastany Fall 2014 UMass Dartmouth, Team 1-9, Shastany Fall 2014 회원
UMASSD-SHASTANY-F14S1G9
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,720
