주요 콘텐츠로 건너뛰기
LG G2 mini LTE Rear Facing Camera Replacement
필요한 것
  1. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery Cover: 1 단계, 이미지 1/1
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily.
  2. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery: 2 단계, 이미지 1/1
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  3. LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: 3 단계, 이미지 1/2 LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: 3 단계, 이미지 2/2
    • Locate 10 screws and remove each one using a screw driver.
  4. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Motherboard Cover: 4 단계, 이미지 1/1
    • Use a plastic spudger tool to pry away the cover by placing it between the cover and the screen bezel.
    • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
  5. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: 5 단계, 이미지 1/3 LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: 5 단계, 이미지 2/3 LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: 5 단계, 이미지 3/3
    • Locate the rear facing camera.
    • Pry the ribbon cable off of it's connector using the plastic spudger tool.
    • Use your finger to remove the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nicholas Van Beek
회원 가입일: 10/23/14
581 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-9, Shastany Fall 2014 UMass Dartmouth, Team 1-9, Shastany Fall 2014 회원
UMASSD-SHASTANY-F14S1G9
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 1,658
