이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This is a replacement guide for the earpiece that is located in the front panel.
필요한 것
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 3개
unless you broke the phone, NO
