주요 콘텐츠로 건너뛰기
LG G3 Screen flicker and fades
필요한 것
  1. LG G3 Screen flicker and fades, Place The Folden Paper Here!: 1 단계, 이미지 1개 중 1개
    • Place The Paper Here On this Connector!
  2. LG G3 Screen flicker and fades, Thermal Paste: 2 단계, 이미지 1개 중 1개
    • A small dot will do the job better than overfilling !
결론
It is not to Hard to perform this Fix.
Just don't touch anything else and be careful while taking the plastic cover off....
Everything is going to be fine.
다른 61명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
albanjakupi
회원 가입일: 02/15/17
1,837 평판
안내서 1개를 작성함
57가이드 댓글
Shume mire !! A ke Informacion si po ndrohet " Displayglass", jo krejt Display, po vetem ajo Pjesa e pare.
Tfala Bekim Jakupi
Bekim Jakupi - 답글
I am not sure who this is going to but I wanted to know about the repair of the flickering and fading screen of the LG G3. Is that procedure a long term fix and what causes the symptoms. Also is the little piece of paper any type of fire hazard. The repair worked and it blows my mind. Thank you so much. I brought my phone to a repair shop and they were unable to fix it, Thank you again. If you wish to respond to me. My name is rich and my E-MAIL address is raidernation61@sbcglobal.net.
raidernation61 - 답글
do you have a gmail ? i want ask about this lg g3 problem . ty
wawan D -
I don't know why, but this works! Thank You!
dlinsc - 답글
Absolutely worked. Thanks for this. The flex cable just need to be push hard to the socket.
Ronald Tariga - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 38
지난 30일: 203
전체 시간: 63,697
