주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G3 Vigor Display Assembly Replacement
필요한 것
  1. LG G3 Vigor Display Assembly Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Display Assembly Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Display Assembly Replacement, Midframe: 4 단계, 이미지 1개 중 1개
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Display Assembly Replacement: 5 단계, 이미지 3개 중 1개 LG G3 Vigor Display Assembly Replacement: 5 단계, 이미지 3개 중 2개 LG G3 Vigor Display Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Display Assembly Replacement, Rear Facing Camera: 6 단계, 이미지 1개 중 1개
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Display Assembly Replacement, Front Facing Camera: 7 단계, 이미지 2개 중 1개 LG G3 Vigor Display Assembly Replacement, Front Facing Camera: 7 단계, 이미지 2개 중 2개
    • Remove the front camera.
  8. LG G3 Vigor Display Assembly Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Display Assembly Replacement: 9 단계, 이미지 2개 중 1개 LG G3 Vigor Display Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Display Assembly Replacement, Vibration Motor: 10 단계, 이미지 1개 중 1개
    • Use a spudger to remove the vibration motor.
    • It may have some slight adhesive, so some force may be necessary.
  11. LG G3 Vigor Display Assembly Replacement, Earpiece Speaker: 11 단계, 이미지 1개 중 1개
    • Remove the earpiece speaker with the metal spudger by prying it out.
  12. LG G3 Vigor Display Assembly Replacement, Headphone Jack: 12 단계, 이미지 1개 중 1개
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
  13. LG G3 Vigor Display Assembly Replacement, Display Assembly: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers peel back the glued down ribbon cable at the bottom of the phone.
  14. LG G3 Vigor Display Assembly Replacement: 14 단계, 이미지 1개 중 1개
    • Using a heat gun or the iFixit iOpener tool heat up the edges of the devices screen.
    • After a few minutes heating up the edges of the screen use a metal spudger tool or any other flat tool to dig under the edge of the screen.
    • Once under the edge of the screen work your way around the entire perimeter of the screen and pull the screen off.
  15. LG G3 Vigor Display Assembly Replacement: 15 단계, 이미지 1개 중 1개
    • Once the screen has come off pull the ribbon cables through the hole and remove the screen completely.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zhong Zhen
회원 가입일: 02/10/16
675 평판
안내서 3개를 작성함
USF Tampa, Team 12-5, Eyestone Spring 2016 USF Tampa, Team 12-5, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G5
4 회원들
안내서 5개를 작성함
2가이드 댓글
i tried to replace the glass, the phone is now stuck at boot screen. the os would load occasionally before. possible battery/water problem. are there any hardware issue that would cause the boot screen (blinking red light)
Ryan Fukushima - 답글 공유
Would anyone know a place to source the glass/lcd assembly. Mucho thanks!
Christopher Obidniak - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 39
전체 시간: 2,381
