주요 콘텐츠로 건너뛰기
LG G3 Vigor Front Facing Camera Replacement
필요한 것
  1. LG G3 Vigor Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 1/1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Front Facing Camera Replacement: 2 단계, 이미지 1/1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Front Facing Camera Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Front Facing Camera Replacement, Midframe: 4 단계, 이미지 1/1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Front Facing Camera Replacement: 5 단계, 이미지 1/3 LG G3 Vigor Front Facing Camera Replacement: 5 단계, 이미지 2/3 LG G3 Vigor Front Facing Camera Replacement: 5 단계, 이미지 3/3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Front Facing Camera Replacement, Front Facing Camera: 6 단계, 이미지 1/2 LG G3 Vigor Front Facing Camera Replacement, Front Facing Camera: 6 단계, 이미지 2/2
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard.
    • Remove the front camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mohammed Albasri
회원 가입일: 02/08/16
155 평판
안내서 1개 작성함
USF Tampa, Team 12-5, Eyestone Spring 2016 USF Tampa, Team 12-5, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 269
