소개
This guide will instruct you on how to replace a cracked or damaged LCD screen and digitizer assembly in your LG G4 smartphone.
It may be necessary to use a pre-cut LG G4 adhesive strip or Tesa 61395 tape to secure your new screen to your device.
필요한 것
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
Front-facing camera connector.
Rear-facing camera connector.
Digitizer connector.
Use a heat gun or iOpener over the auxiliary port to soften the adhesive that secures it to the plastic housing.
이 단계에 사용된 도구:Spudger$2.99
Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
Use a spudger to carefully remove these components and then place them in the new display assembly..
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Use a heavy duty suction cup and firmly pull the screen away from the frame to create a small gap.
이 단계에 사용된 도구:iFixit Opening Picks (Set of 6)$4.99
Insert a plastic opening pick into the gap between the screen and the plastic housing.
Slide the plastic opening pick along the border of the screen to break any additional adhesive and free the screen assembly.
다른 23명이 해당 안내서를 완성하였습니다.
댓글 4개
Per the LG G4 Teardown guide, the glass, digitizer, and LCD are all fused together, so you have to replace the whole assembly
Lorsqu’on remplace l’ensemble écran + LCD achetés ensemble et que l’on transfère les pièces de l’ancien cadre (caméra, vibreur…), il ne faut pas oublier de transférer également 3 petits caoutchoucs carrés noir ou gris (2 en haut de chaque coté du haut parleur, et 1 en bas à gauche de la prise jack), sinon le détecteur de proximité ne marche pas et l’écran s’éteint et le reste lorsqu’on téléphone…
C'est bien qu'on fasse cette observation. Mon technicien avait omis ces neoprenes et j'ai pu les transférés.
My tech had omitted these pads. I am super grateful someone commented that the phone would black out on a call. Problem solved!
