주요 콘텐츠로 건너뛰기
LG G4 LCD and Digitizer Replacement
필요한 것
  1. LG G4 LCD and Digitizer Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 LCD and Digitizer Replacement: 2 단계, 이미지 1/2 LG G4 LCD and Digitizer Replacement: 2 단계, 이미지 2/2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 LCD and Digitizer Replacement: 3 단계, 이미지 1/3 LG G4 LCD and Digitizer Replacement: 3 단계, 이미지 2/3 LG G4 LCD and Digitizer Replacement: 3 단계, 이미지 3/3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 LCD and Digitizer Replacement: 4 단계, 이미지 1/3 LG G4 LCD and Digitizer Replacement: 4 단계, 이미지 2/3 LG G4 LCD and Digitizer Replacement: 4 단계, 이미지 3/3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 LCD and Digitizer Replacement, Motherboard: 5 단계, 이미지 1/2 LG G4 LCD and Digitizer Replacement, Motherboard: 5 단계, 이미지 2/2
    • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
    • Front-facing camera connector.
    • Rear-facing camera connector.
    • Digitizer connector.
    • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
  6. LG G4 LCD and Digitizer Replacement: 6 단계, 이미지 1/2 LG G4 LCD and Digitizer Replacement: 6 단계, 이미지 2/2
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
  7. LG G4 LCD and Digitizer Replacement, Screen Assembly: 7 단계, 이미지 1/1
    • Use a heat gun or iOpener over the auxiliary port to soften the adhesive that secures it to the plastic housing.
  8. LG G4 LCD and Digitizer Replacement: 8 단계, 이미지 1/2 LG G4 LCD and Digitizer Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
  9. LG G4 LCD and Digitizer Replacement, Other components: 9 단계, 이미지 1/1
    • You may also need to remove the vibration motor (the small circular component with two gold contacts), ear-speaker, and two rubber covers on either side of the ear-speaker to transfer these over to the new display assembly.
    • Use a spudger to carefully remove these components and then place them in the new display assembly..
  10. LG G4 LCD and Digitizer Replacement, LCD and Digitizer: 10 단계, 이미지 1/2 LG G4 LCD and Digitizer Replacement, LCD and Digitizer: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $3.99
    구매
    • Use a pair of tweezers to remove the adhesive strip that secures the digitizer ribbon cable.
  11. LG G4 LCD and Digitizer Replacement: 11 단계, 이미지 1/2 LG G4 LCD and Digitizer Replacement: 11 단계, 이미지 2/2
    • Insert the flat side of a nylon spudger below the digitizer ribbon cable to free it from the adhesive.
    • You may use your fingers to pull the ribbon cable gently as you free the panel from the adhesive with the spudger. It may be necessary to apply more heat if the adhesive is still too strong.
  12. LG G4 LCD and Digitizer Replacement: 12 단계, 이미지 1/2 LG G4 LCD and Digitizer Replacement: 12 단계, 이미지 2/2
    • Use a heat gun or an iOpener to soften the adhesive underneath the edges of the screen.
  13. LG G4 LCD and Digitizer Replacement: 13 단계, 이미지 1/2 LG G4 LCD and Digitizer Replacement: 13 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    구매
    • Use a heavy duty suction cup and firmly pull the screen away from the frame to create a small gap.
    • There is a very thin strip of adhesive that holds the screen to the frame; this step should not require excessive force. Apply additional heat along the edges of the phone if the screen is difficult to free.
  14. LG G4 LCD and Digitizer Replacement: 14 단계, 이미지 1/3 LG G4 LCD and Digitizer Replacement: 14 단계, 이미지 2/3 LG G4 LCD and Digitizer Replacement: 14 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    구매
    • Insert a plastic opening pick into the gap between the screen and the plastic housing.
    • Slide the plastic opening pick along the border of the screen to break any additional adhesive and free the screen assembly.
  15. LG G4 LCD and Digitizer Replacement: 15 단계, 이미지 1/3 LG G4 LCD and Digitizer Replacement: 15 단계, 이미지 2/3 LG G4 LCD and Digitizer Replacement: 15 단계, 이미지 3/3
결론
다른 23명이 해당 안내서를 완성하였습니다.
Richard
회원 가입일: 02/07/17
30,037 평판
안내서 11개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 4개
It is possible replace the digitalizer only? Thanks
Nene indy - 답글
Per the LG G4 Teardown guide, the glass, digitizer, and LCD are all fused together, so you have to replace the whole assembly
Eric Clothier - 답글
Lorsqu’on remplace l’ensemble écran + LCD achetés ensemble et que l’on transfère les pièces de l’ancien cadre (caméra, vibreur…), il ne faut pas oublier de transférer également 3 petits caoutchoucs carrés noir ou gris (2 en haut de chaque coté du haut parleur, et 1 en bas à gauche de la prise jack), sinon le détecteur de proximité ne marche pas et l’écran s’éteint et le reste lorsqu’on téléphone…
Nevile - 답글
C'est bien qu'on fasse cette observation. Mon technicien avait omis ces neoprenes et j'ai pu les transférés.
My tech had omitted these pads. I am super grateful someone commented that the phone would black out on a call. Problem solved!
Sidney Stratton -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 24
전체 시간: 23,082
