이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
Detach the cover with your fingers
Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
Front-facing camera connector.
Rear-facing camera connector.
Digitizer connector.
Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
Use a heat gun or iOpener over the auxiliary port to soften the adhesive that secures it to the plastic housing.
이 단계에 사용된 도구:Spudger$2.99-
Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
Use a spudger to carefully remove these components and then place them in the new display assembly..
이 단계에 사용된 도구:Tweezers$3.99-
Use a pair of tweezers to remove the adhesive strip that secures the digitizer ribbon cable.
Insert the flat side of a nylon spudger below the digitizer ribbon cable to free it from the adhesive.
Use a heat gun or an iOpener to soften the adhesive underneath the edges of the screen.
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95-
Use a heavy duty suction cup and firmly pull the screen away from the frame to create a small gap.
이 단계에 사용된 도구:iFixit Opening Picks (Set of 6)$4.99-
Insert a plastic opening pick into the gap between the screen and the plastic housing.
Slide the plastic opening pick along the border of the screen to break any additional adhesive and free the screen assembly.
다른 23명이 해당 안내서를 완성하였습니다.
댓글 4개
Per the LG G4 Teardown guide, the glass, digitizer, and LCD are all fused together, so you have to replace the whole assembly
Lorsqu’on remplace l’ensemble écran + LCD achetés ensemble et que l’on transfère les pièces de l’ancien cadre (caméra, vibreur…), il ne faut pas oublier de transférer également 3 petits caoutchoucs carrés noir ou gris (2 en haut de chaque coté du haut parleur, et 1 en bas à gauche de la prise jack), sinon le détecteur de proximité ne marche pas et l’écran s’éteint et le reste lorsqu’on téléphone…
C'est bien qu'on fasse cette observation. Mon technicien avait omis ces neoprenes et j'ai pu les transférés.
My tech had omitted these pads. I am super grateful someone commented that the phone would black out on a call. Problem solved!
