소개
This guide will show you how to replace the Motherboard.
필요한 것
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
Front-facing camera connector.
Rear-facing camera connector.
Digitizer connector.
다른 54명이 해당 안내서를 완성하였습니다.
댓글 25개
Where can I get a motherboard? I have been looking everywhere with no luck.
If you had it less then a year lg will send u a replacement but if your phone is damaged they will charge u just say it's not damage and swap the boards and send them the new one back so u won't be charged they won't notice I just did it
i have to ask did they ever notice with the swap???
mklb492 -
If my phone has the boot loop problem and i change the board will mi picture still be there ??
Did you find a resolution to this problem? I am facing the same thing!
