주요 콘텐츠로 건너뛰기
LG G4 Screen Assembly Replacement
필요한 것
  1. LG G4 Screen Assembly Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Screen Assembly Replacement: 2 단계, 이미지 2개 중 1개 LG G4 Screen Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Screen Assembly Replacement: 3 단계, 이미지 3개 중 1개 LG G4 Screen Assembly Replacement: 3 단계, 이미지 3개 중 2개 LG G4 Screen Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Screen Assembly Replacement: 4 단계, 이미지 3개 중 1개 LG G4 Screen Assembly Replacement: 4 단계, 이미지 3개 중 2개 LG G4 Screen Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Screen Assembly Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 LG G4 Screen Assembly Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
    • Front-facing camera connector.
    • Rear-facing camera connector.
    • Digitizer connector.
    • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
  6. LG G4 Screen Assembly Replacement: 6 단계, 이미지 2개 중 1개 LG G4 Screen Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
  7. LG G4 Screen Assembly Replacement, Screen Assembly: 7 단계, 이미지 1개 중 1개
    • Use a heat gun or iOpener over the auxiliary port to soften the adhesive that secures it to the plastic housing.
  8. LG G4 Screen Assembly Replacement: 8 단계, 이미지 2개 중 1개 LG G4 Screen Assembly Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
  9. LG G4 Screen Assembly Replacement, Other components: 9 단계, 이미지 1개 중 1개
    • You may also need to remove the vibration motor (the small circular component with two gold contacts), ear-speaker, and two rubber covers on either side of the ear-speaker to transfer these over to the new display assembly.
    • Use a spudger to carefully remove these components and then place them in the new display assembly..
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
474,972 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 18
전체 시간: 1,735
