주요 콘텐츠로 건너뛰기
LG G4 Speaker Replacement
필요한 것
  1. LG G4 Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Speaker Replacement: 2 단계, 이미지 1/2 LG G4 Speaker Replacement: 2 단계, 이미지 2/2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Speaker Replacement: 3 단계, 이미지 1/3 LG G4 Speaker Replacement: 3 단계, 이미지 2/3 LG G4 Speaker Replacement: 3 단계, 이미지 3/3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Speaker Replacement: 4 단계, 이미지 1/3 LG G4 Speaker Replacement: 4 단계, 이미지 2/3 LG G4 Speaker Replacement: 4 단계, 이미지 3/3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Speaker Replacement, Speaker: 5 단계, 이미지 1/2 LG G4 Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • Detach the bottom portion of the plastic panel you just removed by wedging the plastic opening tool under the top part of the clip, and sliding the bottom portion of the panel downward away from the top portion.
    • The bottom portion of the plastic panel contains the speaker to be replaced, all as one part.
결론
다른 8명이 해당 안내서를 완성하였습니다.
carolinavind
회원 가입일: 08/30/15
2,699 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-5, Wollert Fall 2015 USF Tampa, Team 16-5, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G5
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 6,998
