주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G5 Front Panel Assembly
필요한 것
  1. LG G5 Front Panel Assembly, Front Panel Assembly: 1 단계, 이미지 2개 중 1개 LG G5 Front Panel Assembly, Front Panel Assembly: 1 단계, 이미지 2개 중 2개
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Front Panel Assembly: 2 단계, 이미지 3개 중 1개 LG G5 Front Panel Assembly: 2 단계, 이미지 3개 중 2개 LG G5 Front Panel Assembly: 2 단계, 이미지 3개 중 3개
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Front Panel Assembly: 3 단계, 이미지 2개 중 1개 LG G5 Front Panel Assembly: 3 단계, 이미지 2개 중 2개
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Front Panel Assembly: 4 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  5. LG G5 Front Panel Assembly: 5 단계, 이미지 2개 중 1개 LG G5 Front Panel Assembly: 5 단계, 이미지 2개 중 2개
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  6. LG G5 Front Panel Assembly: 6 단계, 이미지 2개 중 1개 LG G5 Front Panel Assembly: 6 단계, 이미지 2개 중 2개
    • Peel the screen away from the body. The two parts should be completely separated.
결론
Now you can access all the inner components of the phone!
다른 32명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joshua Zalmanowitz
회원 가입일: 09/27/16
1,817 평판
안내서 4개를 작성함
Cal Poly, Team 18-2, Forte Fall 2016 Cal Poly, Team 18-2, Forte Fall 2016 회원
CPSU-FORTE-F16S18G2
4 회원들
안내서 15개를 작성함
4가이드 댓글
quickest 50 bucks i ever made, lol. Thanks for having the guide up.
Montez Hardnett - 답글
Love this phone... So MODULAR! Thanks for the guide.. Had to double-check when I was pulling it apart.. almost seemed too easy.
Christopher Williams - 답글
Wow, I didn't realise this phone was so modular, reminds me of the s4. I wish more phone were like it!!
Lucas - 답글
Busted my screen running it up the side to pry it off. Next time I'd do the two bottom sides and lift up. The tapered edge on top seems to have been the problem for me.
Randy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 65
전체 시간: 10,217
