소개
In this guide, you will be removing the screen from the phone, so that you may replace a cracked or malfunctioning screen. This will involve prying the screen out of the phone, unscrewing the motherboard, and disconnecting the screen tether from the motherboard.
필요한 것
While holding the battery release button, pull the bottom end of the phone out of the body.
Insert the plastic opening tool into the seam between the glass screen and the metal body.
Pry the glass from the body only a slight amount.
It is, i can’t seem to do it too easily either. Maybe i need to heat it up? I don’t want to damage it as it will still be used as a camera.
Insert the Spudger into the now open space between the body and screen.
Push inward to separate the screen even more.
Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
My LCD started to let loose using this way to saparate the top and bottom of the phone.
I used a guitar pick and slided it from the bottom to the top like the dude in this video: https://www.youtube.com/watch?v=XV10zyw8...
Didn’t had to use a lot of force this way, and my screen almost didn’t bend !
Yep! I did it also with this method. Wayy better and easier ;)
I found it easier to run the tool or a pick along the sides, and then sort of hinge the thing open at the top rather than running completely around the screen. It gets a little dicey where the glass starts to curve.
Once the screen has been separated from the back of the phone, now you can remove the motherboard.
Using the #00 Philips head, remove the six 2.7mm Phillips screws.
Separate the motherboard of the phone from the screen of the phone
Don't forget to take out the speaker and the rubber parts that need to be transferred to the other frame.
We had to move to the new assembly:
tiny rubber part to the left of the speaker contacts (pinned by the plastic speaker housing)
speaker (aka earpiece - step 10)
plastic speaker housing (aka earpiece casing - step 11)
tiny front facing camera
left rear camera (the middle rear camera stayed on the logic board).
other than that, the guide, combined with careful observation, was help us successfully replace the broken screen.
Make sure to transfer the earpiece from the old screen to the new screen or else you wouldn't be able to hear anyone when you make phone calls!
The component is fragile so don't try to force it to come out with a pair of tweezers. A pick should be able to wedge it out.
Be careful with the adhesive that's connected to it. It's easy to pull out.
I have a G5 SE. The earpiece is slightly different. I pried close to the screw and the whole plastic casing came out as one. Skip step 11. The regular G5 looks like this guide.
다른 91명이 해당 안내서를 완성하였습니다.
댓글 13개
I just did a screen replacement following this guide. The #000 phillips fit a lot better than the #00, but otherwise this guide was great. It took about 15 minutes to do from start to finish and I'd say it was one of the more easy replacements I've had to do, since there were minimal components that had to be transferred over from the old to the new screen.
Thanks!
this is great - success - thank you. A little confusing between step 4 and 5 as I think you reverse angles on the photos - in step 4 the motherboard is right under where you have the opening tool and in step 5 you have the spudger on the other side.
one of the 2 screws from the bottom pinged across the room when I did this and I'm pretty sure I don't have any hope of finding it perhaps until I move house. Any ideas on where I can find another? UK based. replacebase doesn't have them. It works fine without, just would like it screwed together properly...
Followed these steps no problem. Only heads up: Make sure that the replacement screen you buy comes a speaker, or make sure you move your old one over. This step isn't shown in the above, and was required for me.
I think the guide could be a bit more completed. Its vague and doesn't seem like a full repair guide.
Screen replaced bit now no Wi-Fi
Is there any solutions to this ?
I have tried bending the contact pins out but this has made no difference
I lost the notification LED light after the replacement of the screen, toggling in setting has no effect. Don’t know if it’s the replacement part or something I did.
There is a rubber part that lies in front of your proximity sensor on your main board that may not be included with your new screen (I’ve had 2 screens come with and two without). If you are experiencing proximity sensor issues it is likely because you forgot to move this part because it was not included with your new screen.
