이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
냄비나 팬에 iOpener가 완전히 잠길 정도로 충분한 물을 채우세요.
물이 끓을 때까지 가열하세요. 불을 끄세요.
iOpener를 뜨거운 물에 2~3분간 담그세요. iOpener가 물에 완전히 잠겼는지 확인합니다.
집게를 사용하여 뜨거운 물에서 가열된 아이오페너를 꺼내세요.
수건으로 iOpener를 완전히 말리세요.
iOpener를 사용할 준비가 되었습니다! iOpener를 재가열해야 한다면 물을 끓인 후 불을 끄고 2~3분 동안 iOpener를 물에 담가 두세요.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Apply a heated iOpener to a long edge of the phone for about 2 minutes.
In the following steps you will be cutting through the adhesive on the rear glass panel.
Take note of the following areas:
In addition to cutting around the edge, there is extra adhesive here that should be cut.
Avoid sticking the spudger blade in too far here, to avoid damaging the rear button ribbon cable and chip.
Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can.
Lift on the suction cup, and insert a halberd spudger or opening pick under the rear glass.
Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
Slide the blade of a Halberd spudger along the side of the phone, separating the adhesive.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use the opening picks to slice through any remaining adhesive and open the phone.
Remove the glass from the phone.
Slide the blade of a halberd spudger into the opening on the edge of the rear button bracket.
Continue sliding the spudger blade around the bracket to cut all the adhesive holding the bracket to the rear case.
Remove the bracket.
Slide an opening pick between the rear button membrane and the rear case.
Slide the pick around the edge of the membrane to separate it from the rear case.
Use the blade of a halberd spudger to pry the rear button chip off of the rear case.
Use an opening pick to pry the contact pad off of the rear case.
Remove the rear button assembly.
Separate the rear glass from the phone,
Remove eleven Philips #00 screws.
Use the flat end of a spudger to disconnect the LCD/Digitizer flex cable.
Use the flat end of a spudger to disconnect the charge port flex cable.
Insert a SIM card opening tool into the small hole on the left side of the phone and remove the SIM card tray.
Use the flat end of a spudger to remove the adhesive securing the USB-C charge port to the frame.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 4개
Excellent AAAAAAAAA ++++
Awesome tutorial, I skipped the from step 11 to 15. No need to remove the button assembly. Just skipped that and reused the back glass panel with no problems. Thank you!
I can’t get the back off. I’ve tried so hard but it wont come off. I pulled so &&^&^$^ hard i cracked the back but couldnt get the &&^&^$^ back off wtf
Hi , I have replaced the port but usb comm still not working. QC3 not working because it also works with working usb comm. I have tried many original cords and chargers.
