주요 콘텐츠로 건너뛰기
LG G6 SIM Card Reader Replacement
필요한 것
    • Insert wisdom here.
결론
작성자
2다른 기여자 명과 함께
MovilOne
회원 가입일: 06/17/14
2,480 평판
안내서 11개를 작성함
3가이드 댓글
Nice Work. Instead of using the iron to solder it to the board, could you use a heat gun instead?
B Thomp - 답글
Yes, use leaded solder and small amount of no clean flux, maximum heat of 250 c, as described my Molex datasheets and part will self align
Greg Hamilton - 답글
We have repaired many of these LG G6 phones with damage to the sim card reader, it looks like it is a very common issue with this phone. The sim card tray gets stuck or jammed inside the reader, and when force is applied to pull the tray out, it ends up damaging the pins for the sim card or memory card reader. It is easily repaired though if you have the correct tools and skills!
smartfonefix - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 13
전체 시간: 4,512
