주요 콘텐츠로 건너뛰기
LG G7 ThinQ Motherboard Replacement
필요한 것
  1. LG G7 ThinQ Motherboard Replacement, SIM Card: 1 단계, 이미지 1/1
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
  2. LG G7 ThinQ Motherboard Replacement, Back Cover: 2 단계, 이미지 1/1
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
  3. LG G7 ThinQ Motherboard Replacement, Speaker System: 3 단계, 이미지 1/1
    • This device did not come with a midframe, but if yours does, follow the instructions in the teardown video to remove it.
    • Remove the screws along the perimeter and central area of the phone using a Phillips #000 screwdriver.
  4. LG G7 ThinQ Motherboard Replacement, Remove the speaker system: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use your fingers or tweezers to remove the speaker system.
  5. LG G7 ThinQ Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Make sure the motherboard is fully disconnected from the battery.
    • Use your fingers or tweezers to remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alivia Catey
회원 가입일: 01/14/21
654 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 59
전체 시간: 2,133
