주요 콘텐츠로 건너뛰기
LG GS170 Battery Replacement
  1. LG GS170 Battery Replacement, Back Cover: 1 단계, 이미지 1/3 LG GS170 Battery Replacement, Back Cover: 1 단계, 이미지 2/3 LG GS170 Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Turn off the the cell phone.
    • Locate the the arrow at the top of the back cover.
    • Slide the cover downward until the cover comes off.
  2. LG GS170 Battery Replacement, Battery: 2 단계, 이미지 1/3 LG GS170 Battery Replacement, Battery: 2 단계, 이미지 2/3 LG GS170 Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Completely remove the back cover, and the battery should be visible.
    • Locate the gap at the bottom right.
    • Use your thumb to pop out the battery.
  3. LG GS170 Battery Replacement: 3 단계, 이미지 1/1
    • The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
    • Be careful of damaged battery. Inspect the battery for crack, rupture of the plastic, excessive leaking, or discoloration. Remove the battery carefully if it appears damaged.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Minna
회원 가입일: 10/08/14
101 평판
안내서 1개 작성함
USF Tampa, Team 1-25, Donnelly Fall 2014 USF Tampa, Team 1-25, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G25
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 9
전체 시간: 449
