주요 콘텐츠로 건너뛰기
LG GW910 Keyboard Replacement
필요한 것
  1. LG GW910 Keyboard Replacement, Motherboard: 1 단계, 이미지 1/2 LG GW910 Keyboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. LG GW910 Keyboard Replacement: 2 단계, 이미지 1/2 LG GW910 Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove the battery by lifting from the bottom.
  3. LG GW910 Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove six 3mm PH000 screws.
  4. LG GW910 Keyboard Replacement: 4 단계, 이미지 1/3 LG GW910 Keyboard Replacement: 4 단계, 이미지 2/3 LG GW910 Keyboard Replacement: 4 단계, 이미지 3/3
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. LG GW910 Keyboard Replacement: 5 단계, 이미지 1/1
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. LG GW910 Keyboard Replacement: 6 단계, 이미지 1/1
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. LG GW910 Keyboard Replacement: 7 단계, 이미지 1/3 LG GW910 Keyboard Replacement: 7 단계, 이미지 2/3 LG GW910 Keyboard Replacement: 7 단계, 이미지 3/3
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
  8. LG GW910 Keyboard Replacement, Keyboard: 8 단계, 이미지 1/1
    • Remove six 1mm PH00 screws.
  9. LG GW910 Keyboard Replacement: 9 단계, 이미지 1/2 LG GW910 Keyboard Replacement: 9 단계, 이미지 2/2
    • Peel off the tape to expose the hidden screw.
    • Replacement tape might be needed.
  10. LG GW910 Keyboard Replacement: 10 단계, 이미지 1/2 LG GW910 Keyboard Replacement: 10 단계, 이미지 2/2
    • Pry off the board from the side using the metal spudger tool.
    • Disconnect the antenna.
  11. LG GW910 Keyboard Replacement: 11 단계, 이미지 1/1
    • Remove the keyboard assembly from the main frame.
    • The keyboard cover is loose.
    • Make sure to pull the small keyboard battery out with the whole assembly
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonas Ke
회원 가입일: 11/06/18
492 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G6, Hovde Fall 2018 IUPUI, Team S1-G6, Hovde Fall 2018 회원
IUPUI-HOVDE-F18S1G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 104
