소개
If your phone's camera breaks or you would like to update it, this guide will show you how to install your phone's camera.
필요한 것
Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
Locate the camera near the upper-left corner and use the metal tweezers to carefully detach the black tab.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
