소개
If your phone's motherboard is faulty, this guide will show you how to safely replace it.
필요한 것
Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
Repeat this for the white tab on the opposite side of the phone.
거의 끝나갑니다!
결론
