주요 콘텐츠로 건너뛰기
LG Intuition Camera Replacement
필요한 것
  1. LG Intuition Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device so the two bottom screws are shown.
  2. LG Intuition Camera Replacement: 2 단계, 이미지 1/1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
  3. LG Intuition Camera Replacement: 3 단계, 이미지 1/1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
  4. LG Intuition Camera Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
  5. LG Intuition Camera Replacement: 5 단계, 이미지 1/1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
  6. LG Intuition Camera Replacement: 6 단계, 이미지 1/2 LG Intuition Camera Replacement: 6 단계, 이미지 2/2
    • Gently raise the battery from its compartment.
  7. LG Intuition Camera Replacement, Plastic Motherboard Shield: 7 단계, 이미지 1/1
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
  8. LG Intuition Camera Replacement: 8 단계, 이미지 1/1
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
  9. LG Intuition Camera Replacement, Camera: 9 단계, 이미지 1/1
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
  10. LG Intuition Camera Replacement: 10 단계, 이미지 1/1
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
결론
Thomas Morrissey
회원 가입일: 10/25/18
616 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S3-G4, Peak Fall 2018 UMass Dartmouth, Team S3-G4, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 101
