주요 콘텐츠로 건너뛰기
LG Intuition Volume Buttons Replacement
필요한 것
  1. LG Intuition Volume Buttons Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device so the two bottom screws are shown.
  2. LG Intuition Volume Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
  3. LG Intuition Volume Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
  4. LG Intuition Volume Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
  5. LG Intuition Volume Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
  6. LG Intuition Volume Buttons Replacement: 6 단계, 이미지 2개 중 1개 LG Intuition Volume Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Gently raise the battery from its compartment.
  7. LG Intuition Volume Buttons Replacement, Plastic Motherboard Shield: 7 단계, 이미지 1개 중 1개
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
  8. LG Intuition Volume Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
  9. LG Intuition Volume Buttons Replacement, Volume Buttons: 9 단계, 이미지 2개 중 1개 LG Intuition Volume Buttons Replacement, Volume Buttons: 9 단계, 이미지 2개 중 2개
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
결론
작성자
1다른 기여자 명과 함께
Thomas Morrissey
회원 가입일: 10/25/18
616 평판
안내서 6개를 작성함
UMass Dartmouth, Team S3-G4, Peak Fall 2018 UMass Dartmouth, Team S3-G4, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 204
