필요한 것
Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
Lift battery up here
Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
5 단계 Motherboard Removal
주의: 5 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
The headphone jack is adhered to the frame, and its flex cable is adhered to the frame and the strip of Kapton tape.
Use heat to soften the adhesive, then insert an opening pick here to separate the flex cable from the frame.
Use an opening pick to pry around the headphone jack to separate it from the adhesive in its housing.
