주요 콘텐츠로 건너뛰기
LG K20 PLUS Midframe Replacement
필요한 것
  1. LG K20 PLUS Midframe Replacement, Remove the back cover and battery: 1 단계, 이미지 1/2 LG K20 PLUS Midframe Replacement, Remove the back cover and battery: 1 단계, 이미지 2/2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Midframe Replacement, Midframe: 2 단계, 이미지 1/1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Midframe Replacement: 3 단계, 이미지 1/2 LG K20 PLUS Midframe Replacement: 3 단계, 이미지 2/2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
결론
Patrick
회원 가입일: 05/14/14
6,586 평판
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 73
