필요한 것
Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
Lift battery up here
Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
이 단계에 사용된 도구:Halberd Spudger$2.99
Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
