주요 콘텐츠로 건너뛰기
LG K20 PLUS Rear-Facing Camera Replacement
필요한 것
  1. LG K20 PLUS Rear-Facing Camera Replacement, Remove the back cover and battery: 1 단계, 이미지 2개 중 1개 LG K20 PLUS Rear-Facing Camera Replacement, Remove the back cover and battery: 1 단계, 이미지 2개 중 2개
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Rear-Facing Camera Replacement, Midframe: 2 단계, 이미지 1개 중 1개
    • Remove 11 Philips screws.
  3. LG K20 PLUS Rear-Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 LG K20 PLUS Rear-Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Rear-Facing Camera Replacement, Rear-Facing Camera: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
결론
작성자
2다른 기여자 명과 함께
Patrick
회원 가입일: 05/14/14
6,767 평판
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 446
